TwinTurbo.NET: Nissan 300ZX forum - Not firing on 3 cylinder?!?!? Last hopes....
Subject Not firing on 3 cylinder?!?!? Last hopes....
Posted by TwinZ's on April 25, 2014 at 8:32 PM
  This message has been viewed 224 times.
Message I just did a auto to manual swap on my 1990 white 5 speed car to a 1990 charcoal 300zx automatic. Im not firing on cylinders 3,5,6. I have rewired the ptu harness so it only has 2 plugs instead 4 and traced the wires back to the main harness and all the connections are correct. I put new injector clips on all the cylinders. I have tested and ohm checked the injectors. I have tested the CAS and made sure the injectors are pulsing. All three grounds are hooked up on the plenum. I have swaped coil packs around from a working cylinder and still no luck.
What else can i do to help narrow down this culprit?
