TwinTurbo.NET: Nissan 300ZX forum - If you use the NA transmission then use the aluminum
Subject If you use the NA transmission then use the aluminum
Posted by na300zx (OH) on April 24, 2014 at 9:18 AM
  This message has been viewed 294 times.
In Reply To NA aluminium flywheel vs stock tt flywheel posted by rykersdad1 on April 22, 2014 at 07:51 PM
Message flywheel. You will have to grind the bellhousing and shim the starter to fit a TT flywheel in an NA transmission (not a big deal, but easier not to). Joe at ZSpeed performance can hook you up with a Southbend clutch that will hold your power and bolt to the NA flywheel.
