TwinTurbo.NET: Nissan 300ZX forum - Re: Timing belt marks
Subject Re: Timing belt marks
Posted by Stadsport (Nick@CZP) on April 23, 2014 at 12:06 AM
  This message has been viewed 264 times.
In Reply To Timing belt marks posted by Stanky on April 23, 2014 at 12:02 AM
Message Looks approximately correct, but it's impossible to tell without removing and replacing the belt or just counting the cogs.
The tensioner gap will change a little here and there as it's rotated, but should be about 4mm when the engine is at TDC. Find a 4mm allen key and see if it fits, that's the easiest way to tell. It's okay for it to be a LITTLE on the tight side, I believe the low-end is 3.8mm.
