TwinTurbo.NET: Nissan 300ZX forum - ..and a bit more than just adding fluid, system will have
Subject ..and a bit more than just adding fluid, system will have
Posted by jzack on April 22, 2014 at 9:12 PM
  This message has been viewed 208 times.
In Reply To ..and yes, it also uses DOT3 brake fluid. (n/m) posted by Khronik on April 22, 2014 at 07:06 PM
Message to be bled to work right. Leaks could be:
- Cluch master cylinder (top of engine bay) -- see if you have any fluid inside the car under the clutch pedal or along where it connects to things. Use a flashlight to inspect under the dash.
- Slave cylinder mounted down by the tranny.
- Short hose that connects the slave to a metal pipe which goes up to the master cylinder.
