TwinTurbo.NET: Nissan 300ZX forum - NA aluminium flywheel vs stock tt flywheel
Subject NA aluminium flywheel vs stock tt flywheel
Posted by rykersdad1 on April 22, 2014 at 7:51 PM
  This message has been viewed 416 times.
Message Ok guys here's the deal. i bought a 93 2+2 obviously na with a motor problem. I then found a great deal on a complete tt drivetrain with intercoolers and piping. I have now got the na motor and trans out and found in the process that it has an aluminium flywheel and aluminium crank pully.
My question is on a stock turbo build would the na flywheel have enough contact surface and would the clutch be strong enough to hold up. i cant afford to but a aluminium tt flywheel so its either stock cast or aftermarket na.
my power ad ons are a full na aftermarket exhaust with megan test pipes and a pacesetter cat back (also already on the car)
an aftermarket boost controller (mostly to keep from having to change the wiring harness)
Pop charger
Thanks for any advice and input.
