TwinTurbo.NET: Nissan 300ZX forum - The ECU provides a ground for the injector to fire ...
Subject The ECU provides a ground for the injector to fire ...
Posted by jzack on April 17, 2014 at 10:55 PM
  This message has been viewed 142 times.
In Reply To Injector pulse(please help) posted by shea1980 on April 17, 2014 at 08:30 AM
Message easy to use a NOID light connected across the injector connector. Cranking the engine should cause the light to blink. If it blinks all is good with the connections to the connector.
If no blinky and with key off, battery disconnected.
Check the injector harness connection back to the ECU connector. Nice long wire back to the right pin on the connector for that injector and then to one lead on your meter. Other meter lead to injector connector and do a resistance or continuity check. That will tell for sure if the wire is good or not?
