TwinTurbo.NET: Nissan 300ZX forum - Do not get these either
Subject Do not get these either
Posted by Cjw3 on April 17, 2014 at 1:18 PM
  This message has been viewed 475 times.
In Reply To Horrible idea posted by -Grimm- on April 17, 2014 at 11:22 AM
Message These are bad also.. Z1 Motorsports 300zx Urethane Motor Mounts..
[ http://www.z1motorsports.com/product_info.php?products_id=5583 ]
I did a Lower Engine Bearing Set on the '92 NA a few weeks ago.. the Cross Member came out with 1/2 of the Engine Mounts still attached.. so it was time to replace..
My Son wanted Aluminum and Shinney.. so we got these..
As I was tightening up the Upper Nut.. I pulled the Stud out of the Aluminum .. made me a little Grumpy..
The Upper Stud ( 10MM ) has only 10MM of thread depth in an ALUMINUM piece.. That is not going to hold much!
I was able to Re-Machine and place a Countersunk Bolt (3/8) INSIDE the Mount upper Half.. and put it all back together..
I did the same to both Mounts..
Other than that.. I like them..
Cj
