TwinTurbo.NET: Nissan 300ZX forum - Transmission rear extension seal.
Subject Transmission rear extension seal.
Posted by Tanley on April 17, 2014 at 8:58 AM
  This message has been viewed 175 times.
Message FSM calls it the rear extesnion. It's the rear portion of the transmission case bolted on and sealed with silicone. Has anyone pulled this part of the transmission apart? How involved is it? In the FSM it looks like you remove the interlock assembly, upper cover, return spring, check ball, control arm and striking arm, then you can unbolt the rear from the transmission?
  • Transmission rear extension seal. - Tanley 08:58:18 04/17/14
