TwinTurbo.NET: Nissan 300ZX forum - its good that you know how to check fuel and spark but..
Subject its good that you know how to check fuel and spark but..
Posted by Red Hawk (CO) on April 14, 2014 at 11:09 PM
  This message has been viewed 253 times.
In Reply To '90 NA Z32 - No Start posted by Hemi on April 13, 2014 at 04:01 PM
Message the fact that the car is not cranking is completely not related. A car motor cranks mechanically by way of the starter, so if its dead in the water then you could have several issues ( bad starter, bad starter solenoid, bad ignition switch, bad relay, faulty wires leading to any of those ) so i would suggest you look up the wiring diagram for the ignition system and probe around with a multimeter and make sure youre getting volts where they should be. there have plenty of instances where people had no cranks from a bad starter relays or faulty starters, so look through the forum and read up!
TT BEAST IN PROGRESS!
