TwinTurbo.NET: Nissan 300ZX forum - Bypassed the boost solenoid
Subject Bypassed the boost solenoid
Posted by rgonzales39355 on April 09, 2014 at 8:27 PM
  This message has been viewed 637 times.
In Reply To (physically). (n/m) posted by SirpriZ on April 08, 2014 at 02:57 PM
Message Thanks for the suggestion. Today when I got home from work I bypassed the boost solenoid. I took out for a test drive and I'm still boosting over 12lbs.
When I got back from the test drive I isolated both of the watergate actuators and applied pressure individually to each one. The one on the driver side is moving so little I can't see it. If I put my hand on it I can feel it move but only a tiny little bit. The waste gate on the passenger side I can't see but I can hear it move. It makes a pinging noise when I release the pressure on it. I think this is a good indication that it is working correctly.
At this point I strongly believe that I have a bad waste gate actuator. If anyone can confirm this or give me another possible to suspect to troubleshoot I will be very thankful.
If I have to replace my actuators will it be easiest to pull the motor. I have never done a motor pull but I think I am capable of doing it. Thanks again for the advice.
JDM TT swap
JWT pop charger
SZ 3 inch downpipe
SZ 3-2.5" test pipe
SZ/RPS lightened flywheel
SZ/RPS 5 puck clutch
unorthodox under drive pulley
UR HI waterpump pulley
unknown brand 2.5" catback
Z1 ECU
Greddy profec B boost controler
Stillen radiator hardpipe
Mishimoto radiator
Deleted hot start solenoid
carbon canister delete
AIV solenoid delete
Cruise Control delete
interior innovation seat skins
