TwinTurbo.NET: Nissan 300ZX forum - Cylinder 1 isnt firing.Please help
Subject Cylinder 1 isnt firing.Please help
Posted by shea1980 on April 09, 2014 at 6:32 AM
  This message has been viewed 187 times.
Message Hi guys,i am having a problem with cylinder 1 it is not firing.So i thought it was the injector,so i bought a replacement and put it into the car and still it isnt firing.So i changed the coil pak from cylinder 1 to cylinder 3 and still nothing,then i put in a new sparkplug didnt work,also i checked the ohms of the injector and got 12.8,checked the voltage goin to the injector which is reading the same as cylinder 7 volts,also i did a compression on cylinder 1 and got 155 psi.Guys i totally stuck and dont know what else maybe wrong.Any help would be fantastic.Thanks all
