TwinTurbo.NET: Nissan 300ZX forum - Yeah looks like I jumped the gun...
Subject Yeah looks like I jumped the gun...
Posted by The Sixth on April 07, 2014 at 1:53 PM
  This message has been viewed 209 times.
In Reply To Something seems off. posted by Woody75 (Denver) on April 07, 2014 at 01:12 PM
Message Just got a reply from DVDBURN, saying there's still a ground issue somewhere. I did state in my email to him that I wasn't sure if it was a must-do situation, but at least in my case it fixed the issue. So I guess its sort of a band-aid fix.
I'm not sure what causes some folks to need/want a grounding kit. Just noisier cars? But I've checked the 3 engine bay grounds repeatedly thru the process, and can't think of what else could be causing it. If I'm reading the ECCS diagram right, the 10 and 20 pin grounds eventually terminate at the F11 terminal. I've tested both battery voltage and coil pack connector voltage with that ground point. Other than an on again off again code 13, I haven't detected any other systems to not be working.
