TwinTurbo.NET: Nissan 300ZX forum - Thanks for the insight. I tested for flow after the dampener
Subject Thanks for the insight. I tested for flow after the dampener
Posted by LivinTheDream on April 02, 2014 at 7:56 PM
  This message has been viewed 196 times.
In Reply To P.S. Symtoms of a bad FPR are usually hard start posted by SirpriZ on April 02, 2014 at 06:13 PM
Message This afternoon and its not blocking anything. The fpr may be going but once fuel is in the rail, even if the presure is high, the injectors should be spraying. Just didn't wanna bother with it last night and wanted to see what people thought while I waited to get back at it. The gates fuel line I had hooked up started delaminating at the most inner wall and I feel debre has my injectors clogged. I'm pulling the rail and going to roll the engine over to see if they are spraying.
I don't know for certain if there could be any other reason for them not delievering fuel if they ohmed out correct and they are clicking farely loud enough to easily hear them.
"torque gets you off the line...& hp gets you over the line." -
TTKeeper
