TwinTurbo.NET: Nissan 300ZX forum - Re: Fuel pressure 55-60psi. Could there be a block in the system
WazTTed
on April 01, 2014 at 5:39 PM
posted by LivinTheDream
on March 31, 2014 at 10:19 PM
check the pressure at idle with the vac source to the reg on and off . sounds like your regs on the way out
LivinTheDream
22:19:48 03/31/14
Re: Fuel pressure 55-60psi. Could there be a block in the system -
WazTTed
17:39:10 04/01/14
car cant idle if its not getting fuel. wont start. no fuel
LivinTheDream
18:15:15 04/01/14
Confirm you are getting fuel out of the FPR.
SirpriZ
17:24:53 04/02/14
P.S. Symtoms of a bad FPR are usually hard start
SirpriZ
18:13:52 04/02/14
Thanks for the insight. I tested for flow after the dampener
LivinTheDream
19:56:40 04/02/14
so fuel flows throughout the system. Injectors are faintly
LivinTheDream
10:37:06 04/03/14
