TwinTurbo.NET: Nissan 300ZX forum - Several things ground behind the radio
Subject Several things ground behind the radio
Posted by ThisIsSparTTa on April 01, 2014 at 11:59 AM
  This message has been viewed 190 times.
In Reply To Re: It looks like your gauge wire is grounding out somewhere. posted by yyyktk1 on April 01, 2014 at 07:44 AM
Message When the radio is pulled out the ground is kind of to the bottom left. I have extra stuff wired in there too, but mine had a few things going to that ground point. FYI, your radio will work with the ground disconnected (mine did accidentally while troubleshooting), but long term you will probably fry it if the difference between the ground your radio is seeing and the actual ground gets too high. I'd check that ground ASAP.
