TwinTurbo.NET: Nissan 300ZX forum - Speedo feeds PS ECU
Subject Speedo feeds PS ECU
Posted by ThisIsSparTTa on April 01, 2014 at 11:55 AM
  This message has been viewed 224 times.
In Reply To no power steering or speedo posted by TJSB on March 31, 2014 at 08:01 PM
Message The speed sensor feeds the speedometer with an analog signal, which the speedo converts into a digital TTL signal to go to the ECU or HICAS controller, depending on your setup. If your speedometer isn't working, then the ECU won't get the signal either and put you into the fail-safe mode that disables power steering.
Without more information right now, could be anything from the speed sensor, to the wiring and harnesses in between, to a bad cluster.
Time to pull out the FSM and start researching.
