TwinTurbo.NET: Nissan 300ZX forum - duty cycle refers to the pulse width modulated signal to the
Subject duty cycle refers to the pulse width modulated signal to the
Posted by aliaZ on March 28, 2014 at 12:06 PM
  This message has been viewed 200 times.
In Reply To Would someone in the know explain how duty cycle posted by SirpriZ on March 27, 2014 at 01:24 PM
Message solenoid. The solenoid actuates a valve with a spring that holds it either open or closed (don't remember which).
pulse width modulation is a method of varying a DC voltage by chopping the voltage into on or off states. Generally speaking, a 50% duty cycle of a 12 volt DC signal will be 6 volts if you take the average of the voltage being 12 volts half the time and 0 volts the other half. A boost controller valve can send this PWM signal to the solenoid to counteract the spring in the valve, so that it can vary how open (or closed) the valve is, and thus controlling how much of the pressure signal is bled off before it gets to your turbo wastegates.
