TwinTurbo.NET: Nissan 300ZX forum - Chirp noise from under the timing belt covers
Subject Chirp noise from under the timing belt covers
Posted by poorkid_Z on March 27, 2014 at 1:15 AM
  This message has been viewed 326 times.
Message I recently finished a very long TT conversion and am in the break-in process with a new engine. After ~160 miles I started hearing a chirp noise at idle that sounded like a belt and after 10 minutes it would go away.
I adjusted my drive belts assuming that was the problem to no avail. I decided to remove the belts one at a time to see if it was a bad bearing in one of the accessories. After all the belts were removed the noise was still present. I removed the D/S T-belt cover and the noise was louder but not pinpoint-able. All pulleys are new and the belt is a 1st gen Power Enterprise Kevlar...
Is it possible to have a chirping t belt or more like dry cam seals?
not sure what my next step should be...
