TwinTurbo.NET: Nissan 300ZX forum - its all of the injectors and i only checked the number one
Subject its all of the injectors and i only checked the number one
Posted by LivinTheDream on March 23, 2014 at 1:33 AM
  This message has been viewed 220 times.
In Reply To Is this on all cylinders, both on a single cylinder, or... posted by -Grimm- on March 23, 2014 at 12:30 AM
Message Spark plug. The four ground wires that bolt to the plenum near the 5th coil pack I have secured them through one of the ACC valve body bolts. Is this OK? Like I said this was all done this way prior and everything was fine. When you say install extra ground wires do you mean like the grounding kits?
"torque gets you off the line...& hp gets you over the line." -
TTKeeper
