TwinTurbo.NET: Nissan 300ZX forum - if "the pedal" is making noise then that would be around
Subject if "the pedal" is making noise then that would be around
Posted by LivinTheDream on March 22, 2014 at 6:53 PM
  This message has been viewed 145 times.
In Reply To clutch pedal posted by DJ2_300zxLover on March 22, 2014 at 06:11 PM
Message Where u wanna look. Clevis pin or not. There is a bushing that goes into the pedal arm hole that the pin goes through. That could be missing. I think there is also a bushing for where the spring sits in the pedal arm. Stick your head under there and take a look while u depress the pedal a bit by hand.
"torque gets you off the line...& hp gets you over the line." -
TTKeeper
