TwinTurbo.NET: Nissan 300ZX forum - Yes and no
Subject Yes and no
Posted by SammybTT(TN) on March 19, 2014 at 9:09 PM
  This message has been viewed 172 times.
In Reply To Quick question about lower plenum removal posted by charleyd on March 19, 2014 at 07:10 PM
Message Since the injectors sit in the fuel rail and the fuel rail is seated in the lower plenum there is a good chance they will be disturbed. You do not have to remove the injectors to remove the lower plenum. It is relatively easy to remove but be aware the lower plenum gaskets are expensive. I also recommend to replace the knock sensor pig tail wiring harness if you are there. Good luck
