TwinTurbo.NET: Nissan 300ZX forum - Re: Compression test with no cams will not work
Subject Re: Compression test with no cams will not work
Posted by theo.laz on March 18, 2014 at 11:24 PM
  This message has been viewed 348 times.
In Reply To Compression test with no cams will not work posted by ZXoltan on March 18, 2014 at 05:30 PM
Message Thanks ZXoltan,
I already know that it is a bad valve job... I have done what you suggested (which is injecting air through the spark-plugs while the cams have been removed; at this point all valves should be "sealed-shut" but I can hear lots of air escaping from the intake valves on cylinders #2 and #4). The valves do not appear to be "bent" - this basically leads me to believe that he didn't do a proper valve lapping on those two cylinders.
My question at this point is the following: "If the bad valves are repaired (at another 'local' machine shop), is a consistent 130psi on all cylinders acceptable?" Basically I am trying to figure-out if a pressure of 130psi across all 6 cylinders is 'ok'. To me a pressure of 130psi seems too low but then again I am not certain (this is far away from the preferred 174psi for a VGE30TT engine). I have already spent roughly $4,500 these last 8 months replacing a ton of stuff on my 300zx... I am trying to avoid burning through another $2,000 for a rebuild engine if I don't have to... :(
