TwinTurbo.NET: Nissan 300ZX forum - the lifters might be frozen for those cylinders
Subject the lifters might be frozen for those cylinders
Posted by Zvil (FL) on March 18, 2014 at 1:03 PM
  This message has been viewed 337 times.
In Reply To the "rebuild-engine blues"... :( posted by theo.laz on March 16, 2014 at 06:57 PM
Message I've seen that happen before..... maybe you can remove all the cam shafts and try another compression test, if the numbers are still low on those cylinders -he failed at valve lapping or the valves are bent and binding in their guides, if the numbers are good then it's time for some refurbed/new lifters.
____________________________________________________
"The dreaded 2nd windshiled wiper swipe when you turn it off its almost like tis showing you that it's boss, and it doesn't have to stop when you tell it to :("-College Boy
(discussion on ptu relocation)
"No good reason to put it there anyway. -Bernie (NoVA)
False -vorpalZ
False. -Bernie (NoVA)
You're correct, there are 3 good reasons -vorpalZ
Wow, right again, just remembered another, make that 4 -vorpalZ"
XD
