TwinTurbo.NET: Nissan 300ZX forum - Bad oil leak at the oil pump
Subject Bad oil leak at the oil pump
Posted by EmilZ on March 17, 2014 at 9:44 AM
  This message has been viewed 316 times.
Message I have a bad oil leak in my 91 2+2. It looks like is come from the front and goes down the passenger side. I've changed the front main seal twice and the leak is still there. From what I've read in the posts it looks like the oil pump gasket. Has anyone changed this gasket without dropping the pan. Once I have the timing belt off it looks like I should be able take the bolts out of the front of the oil pump and possible pry the pump forward a 1/16" and work the gasket out. Has anyone tried this. I just don't look forward to having to drop the oil pan. Thanks for your comments.
