TwinTurbo.NET: Nissan 300ZX forum - Re: 174 psi is perfect, but even on newly rebuilt engines
Subject Re: 174 psi is perfect, but even on newly rebuilt engines
Posted by theo.laz on March 16, 2014 at 10:32 PM
  This message has been viewed 360 times.
In Reply To 174 psi is perfect, but even on newly rebuilt engines posted by Tanley on March 16, 2014 at 09:38 PM
Message so, would 130psi be considered "acceptable" for a rebuild engine? My understanding was that lower cylinder pressures were attributed to bad rings (please note, injecting a little oil in the cylinders did not make a difference in the compression results on any of the cylinders in my rebuild engine). Basically I am trying to figure-out if simply fixing the leaking valves may not be enough...
