TwinTurbo.NET: Nissan 300ZX forum - It's not so bad
Subject It's not so bad
Posted by -Grimm- on March 13, 2014 at 6:20 PM
  This message has been viewed 214 times.
In Reply To New guy... New old Z... New problems... posted by Rwrightphotography on March 13, 2014 at 06:16 PM
Message You don't have to be at TDC, any place will work.
For your case, I would take the covers off (requires removing the rad, fan, water pipes) and use a pry bar to hold the tensioner where it is, loosen the two bolts and nut holding it on, let it relax slightly and retighten everything.
Then use a wrench (or the starter) to turn the engine a turn or more (and backwards if you have a wrench) and check the actuator length (easy once you see it)
1992 300ZX NA 5 Sp (Dead)
1990 300ZX NA Auto 2+2 (Dead)
1990 300ZX TT 5 Sp (Building)
2004 G35 Sport 6MT (DD)
