TwinTurbo.NET: Nissan 300ZX forum - Re: weird left hand turn signal problem(not blinking too fast)
Subject Re: weird left hand turn signal problem(not blinking too fast)
Posted by gbhrps on March 10, 2014 at 1:55 PM
  This message has been viewed 213 times.
In Reply To weird left hand turn signal problem(not blinking too fast) posted by tian2bing on March 10, 2014 at 12:34 PM
Message tian2bing,
You don't say whether the signal flashes or not, or if its just that the signal doesn't stay locked on until you straighten the wheel. Your issue sounds like either the plastic pawl that locks the turn signal on until you straighten the wheel, or the contacts for firing up the turn signal lights has yielded to old age.
The only way to fix the problem is to remove the steering wheel cover etc. and get to the turn signal switch body. Whether its a dirt issue or a worn part issue can only be determined then.
If a new switch assembly is required, try eBay or a wrecker for a used one, or Nissan or ConceptZ (online 300zx parts supplier) for a new one. Good Luck!
