TwinTurbo.NET: Nissan 300ZX forum - Zemulator issue and error lights on with no key in ignition.
Subject Zemulator issue and error lights on with no key in ignition.
Posted by poorkid_Z on March 06, 2014 at 12:38 AM
  This message has been viewed 259 times.
Message Long story short. After 6 very long years my TT conversion is almost complete, and I thought I'd load a TT map in my zemulator (1.5.3) before I primed and started my engine tomorrow, I turned my ignition to the on position for the first time (after 6 years) and connected my zem, proceeded to load the base map and noticed for some reason after I wrote to the zem then re-read my map it was changing the injector value from 720cc to 270cc, the dual filtration to single, or the override would be selected and changed. I tried this multiple times and it almost always was different.
After being stumped I disconnected and pulled my key out of the ignition. To further rub salt in my wound my check engine, brake, seatbelt, washer fluid, abs light, etc all were on with the key removed.
I am unsure if I have a relay stuck open or some issue with my zem software creating this issue.
Any advise or starting points would be helpful and appreciated.
