TwinTurbo.NET: Nissan 300ZX forum - not that simple I'm afraid..
Subject not that simple I'm afraid..
Posted by Medallion Man on March 02, 2014 at 2:44 AM
  This message has been viewed 194 times.
In Reply To Front end shakes posted by BROOK-DADDY on March 01, 2014 at 11:15 PM
Message you'll need to get it to someone who can check, could be bearing, steering, upper camber arm, lower control arm bushing, torsion rod loose or bushing, drop links or issues with breaks causing warped disk.
Most mechanics should have a ramp that puts stress on the front components.. with any luck that should show up the issue..
uneven wear on the front tyres or play in wheel bearing might help to narrow it down.
check pads for uneven wear.
good luck.
