TwinTurbo.NET: Nissan 300ZX forum - Code 21 is calling it a PRIMARY wiring problem
Subject Code 21 is calling it a PRIMARY wiring problem
Posted by Cjw3 on February 27, 2014 at 8:23 PM
  This message has been viewed 195 times.
In Reply To Code 21....out of ideas. posted by The Sixth on February 24, 2014 at 10:06 PM
Message And you verified that you do not have spark at the coil..
For the ECU to 'See' the spark.. id have to be sensing the current coming back the PTU line that it grounds at the ECU from the PTU..
So it's a PTU +12 problem, or it's a PTU Problem... or it's a wiring problem from the PTU to the ECU.. or it's an ECU problem..
Toss in another ECU ( any Year any trans, NA or TT ) and see if you can get the Coil to spark to the Plenum during cranking..
From what you have checked, it sounds like the ECU Driver for the PTU pack, might be toast..
But the Replacement ECU will be the final check..
Cj
