TwinTurbo.NET: Nissan 300ZX forum - I cleaned and verified the grounds and battery terminals
Subject I cleaned and verified the grounds and battery terminals
Posted by turb0wed on February 26, 2014 at 10:11 AM
  This message has been viewed 188 times.
In Reply To Recheck your battery terminals posted by 300ZMang on February 25, 2014 at 01:25 PM
Message there is however a detail that I would like to shed light on. The ground whole in the alternator casing was stripped so I pulled a nut off of a stud on the casing and attached the ground there. Could there be a problem there if the studs are attached to the coil? Also I tested the voltage on the battery with the car running i got 14.4 volts or so (oscillation)
Imma boost underpresser leave your money on the
dresser.
