TwinTurbo.NET: Nissan 300ZX forum - u need to review everything from spark / fuel / and
Subject u need to review everything from spark / fuel / and
Posted by The Devils Z on February 24, 2014 at 6:09 PM
  This message has been viewed 147 times.
In Reply To Re: what tune do you have? posted by ouikikazz on February 24, 2014 at 04:04 PM
Message all the connections (electrical). I would 1 of each so that you can do your own diagnosis
1) extra coil pack
2) extra injector (doesn't matter what size - you will just use this to connect to the wiring harness while in hand to see if it clicks)
3) extra spark plugs
4) extra working MAF
5) extra CAS
chances are given the winter - the car is running rich for cold start and fouling the iridium plugs - especially if you are not starting it much. I am chasing a similar problem now.
you can check everything with an extra part as I listed above. You can swap coil packs / check the power source to the injectors / and swap out spark plugs (I would save some pfr6b-11 or 11b just for this reason).
You might want to disconnect your o2s so that you dont have the ECU pulling and throwing fuel at the Z at idle.
ofcourse, do this when the car is warm and make sure your Temp sensor and TPS are in spec. A conzult helps as well to monitor everything and to perform a power balance test.
=============Sig begins here================
The Devils Z.com
800 rwhp dyno
View Me! Disclaimer : Not Safe For Work !
Kid :" Those old guys drive that way ?"
Witness : "Yeah, I rode behind them at ZNationals 2010 on these back roads leaving the track day and they were foot in. They ran into the curves w/no brakes and didn't lift!"
- Hampton Inn parking lot at ZNationals 2011 -
