TwinTurbo.NET: Nissan 300ZX forum - Noticed a drop in oil press at light throttle 2k rpm
Subject Noticed a drop in oil press at light throttle 2k rpm
Posted by TurbodreamZ on February 20, 2014 at 8:17 PM
  This message has been viewed 158 times.
In Reply To That would be the first thing to check posted by -Grimm- on February 20, 2014 at 06:22 PM
Message So I'm guessing the bad pcv is causing a lot of vacuum in the crank case lowering the oil pressure until I either let off the throttle or built boost. As soon as I do either I can watch the oil pressure needle raise back up.
Waiting on new valves from autozone.
