TwinTurbo.NET: Nissan 300ZX forum - Re: CZP HICAS rod end conversion.
The Sixth
on February 20, 2014 at 3:52 PM
posted by YlwPrlZTT
on February 20, 2014 at 02:23 PM
Unless you're planning on removing the knuckle, you're going to want a pitman puller to remove the ball joint and a ball joint press to get the new bushing in.
You can rent both from Autozone.
YlwPrlZTT
14:23:31 02/20/14
Re: CZP HICAS rod end conversion. -
The Sixth
15:52:31 02/20/14
Will a c clamp work instead of the ball joint press? It seem
YlwPrlZTT
08:35:00 02/21/14
Not as easy but yes it will. I have used a C-clamp before. (n/m)
Woody75 (Denver)
09:26:13 02/21/14
Like Woody says, you CAN use one...
The Sixth
10:16:51 02/21/14
Great, thanks for the help. I will rent one out then. (n/m)
YlwPrlZTT
11:35:29 02/21/14
Free until you break it! (n/m)
WhiTTe Z (NY)
17:27:07 02/21/14
