TwinTurbo.NET: Nissan 300ZX forum - ^^2nd Plumb the fuel rail and injectors to compressed air
Subject ^^2nd Plumb the fuel rail and injectors to compressed air
Posted by SammybTT(TN) on February 19, 2014 at 12:04 PM
  This message has been viewed 179 times.
In Reply To Here is how I have done it. posted by Woody75 (Denver) on February 19, 2014 at 11:34 AM
Message and submerge in water and look for leaks. I used this method and let them set overnight or some extended period of time to preform a pressure decay test which is basically the same method as a leak down test. Had a friend that actualy left the fuel rail intact and placed a catch pan under it to check the injector function, personally I don't recommend that technique.
Thanks for the 9V battery trick Woody! I will use that next round!
