TwinTurbo.NET: Nissan 300ZX forum - I would check the timing belt and see if the gears
Subject I would check the timing belt and see if the gears
Posted by Zvil (FL) on February 18, 2014 at 4:58 PM
  This message has been viewed 201 times.
In Reply To UPDATE! Reasonable compression...no spark posted by ThisIsSparTTa on February 14, 2014 at 09:16 AM
Message are on their marks, when a whole side makes low numbers it's either jumped timing/ incorrect installation OR that bank had a bad o2 sensor and the ecu jacked up the fuel trims to the point of detonation/ excessive EGT's
____________________________________________________
"The dreaded 2nd windshiled wiper swipe when you turn it off its almost like tis showing you that it's boss, and it doesn't have to stop when you tell it to :("-College Boy
(discussion on ptu relocation)
"No good reason to put it there anyway. -Bernie (NoVA)
False -vorpalZ
False. -Bernie (NoVA)
You're correct, there are 3 good reasons -vorpalZ
Wow, right again, just remembered another, make that 4 -vorpalZ"
XD
