TwinTurbo.NET: Nissan 300ZX forum - Re: 1991 Speedometer -- Intermittent...
Subject Re: 1991 Speedometer -- Intermittent...
Posted by Kutdawg on February 10, 2014 at 8:42 AM
  This message has been viewed 249 times.
In Reply To 1991 Speedometer -- Intermittent... posted by thumper300zx on February 08, 2014 at 01:23 PM
Message I had a similar problem. speedo only worked when going above 45, and when it started cutting out, the steering got hard, hicas light came on. pulled the codes, and code said it was speed sensor. Took it to the dealership for repair, they first said it wasnt the speed sensor, but a module on the speedo. they replaced that, still didnt work. then they said it was the entire cluster motherboard. they replaced that, still didnt work. Finally i told them to recheck the speed sensor. bingo! speed sensor fixed the problem. hope that helps!
