TwinTurbo.NET: Nissan 300ZX forum - That's a common issue with the vg engines
Subject That's a common issue with the vg engines
Posted by SirpriZ on February 09, 2014 at 6:01 PM
  This message has been viewed 297 times.
In Reply To Compression test posted by Kutdawg on February 09, 2014 at 01:56 PM
Message There tends to be more Airflow to the back two cylinders (#5 and #6) . They then run leaner and the rings are subject to more wear....and less compression. I would't concern myself with the differential in compression numbers. There are some good running zs with alot worse. Bytheway, just make one post about the same subject...posting more is just going to irritate people. You can go back and delete any post if no one has responded to it. Good luck, mark
