TwinTurbo.NET: Nissan 300ZX forum - Re: the trick is to remove the pump from the mount
Subject Re: the trick is to remove the pump from the mount
Posted by Matt300ZXT on February 06, 2014 at 10:29 AM
  This message has been viewed 167 times.
In Reply To the trick is to remove the pump from the mount posted by Zvil (FL) on February 04, 2014 at 07:32 PM
Message I had the pump mounted and had absolutely zero problems getting a torque wrench on it. I had to use a short extension but I was able to do it. Of course I had everything removed when I did the p/s pump and alternator job but it was a breeze to torque the bolt down.
