TwinTurbo.NET: Nissan 300ZX forum - the trick is to remove the pump from the mount
Subject the trick is to remove the pump from the mount
Posted by Zvil (FL) on February 04, 2014 at 7:32 PM
  This message has been viewed 217 times.
In Reply To I don't recall getting a torque wrench onto that big one posted by LJZTT on February 04, 2014 at 02:18 PM
Message you can access the bolt easier and you have more freedom to maneuver the fitting onto the pump to thread the bolt....
"but then how do you hold the pump still while removing/ tightening the banjo bolt"
Option A: Impact gun and extension
Option B: Long open end wrench on lower fitting and breaker bar on banjo bolt
Option C: bolt through pump into mount and breaker bar with extension
____________________________________________________
"The dreaded 2nd windshiled wiper swipe when you turn it off its almost like tis showing you that it's boss, and it doesn't have to stop when you tell it to :("-College Boy
(discussion on ptu relocation)
"No good reason to put it there anyway. -Bernie (NoVA)
False -vorpalZ
False. -Bernie (NoVA)
You're correct, there are 3 good reasons -vorpalZ
Wow, right again, just remembered another, make that 4 -vorpalZ"
XD
