TwinTurbo.NET: Nissan 300ZX forum - Overboost issue solved with ebc (hks evc-s)
Subject Overboost issue solved with ebc (hks evc-s)
Posted by moxie (SF) on February 04, 2014 at 4:21 PM
  This message has been viewed 1781 times.
Message One more for the record books. My car was overboosting badly with my newly installed EBC.
Issue:
- Car would overboost, EBC could not control the amount of boost the turbo's produced
Symptoms:
- overboosting in all gears
- adjusting the EBC had no impact on boost
The fix:
- re-plumb all the vacuum lines from the wastegate up to the EBC
I was having trouble passing smog with the manual boost controller the previous owner installed so I finally got around to installing a hks evc-s to control the boost. I ripped out the manual boost controller and to save time, I tee'd the hks unit into the stock lines instead of doing a full re-plumb.
Once I got it all hooked up, it overboosted like crazy, it didn't matter what I set the hks unit to do, it just ignored all input from the evc.
I read that the there were restrictors in the factory vacuum lines closer to the wastegate itself and that was the only thing other than a bad evc that I could think of that would cause the issue. I spent the afternoon and replaced the factory lines with silicon lines to the wastegates and to the evc. Once re-plumbed, the car boosts properly and the evc is able to control it as expected
Sig Quotes:
your brillant (n/m)
- Zski (Generation Z) 14:36:48 06/17/04
Fat kids will eat
anything. (n/m)
- SooperZ95 22:13:47 07/05/04
BTW, spelling has
nothing to do with being stupid, stupid.
- AzHeat 22:08:35 11/21/04
First of all, we
already know you're a little pussy bitch from San
Francisco
- Marshall 21:36:41 06/08/05
North Dakota is so
flat you can watch your dog run away from you for 3 days.
- BeegsTT 13:31:27 06/15/06
The City of Santa
Monica can fornicate itself with an iron stick.
- 93TTSuperWHiteZX 17:20:16 10/31/06
I work with
fiberglass you stupid f***
- TheTwinZ (Peru) 12:25:30
03/27/07
People who are willing to sacrifice
Freedom for safety deserve neither
- Benjamin Franklin -
Are you in the
know?
