TwinTurbo.NET: Nissan 300ZX forum - Re: My pass window motor failed. Fairly easily to replace. If it
Subject Re: My pass window motor failed. Fairly easily to replace. If it
Posted by gbhrps on January 29, 2014 at 7:57 PM
  This message has been viewed 252 times.
In Reply To My pass window motor failed. Fairly easily to replace. If it posted by YlwPrlZTT on January 29, 2014 at 06:58 PM
Message zx299,
The window sag is easily fixed. Once you correct the problem with the motor/amplifier, if neither makes the window raise to its proper height, there are upper movement stops that can be adjusted with a socket.
Basically you loosen them off a bit, raise the glass to the desired maximum height, and then tighten the adjusters.
If you get to that stage and have problems adjusting the glass, post again and someone here will be able to post the page from the FSM (factory service manual) showing how to accomplish the adjustment.
