TwinTurbo.NET: Nissan 300ZX forum - Power Window Trouble
Subject Power Window Trouble
Posted by ahaav on January 29, 2014 at 4:37 PM
  This message has been viewed 260 times.
Message I haven't torn apart my door panels yet, but my driver side power window motor stopped working. When going in to replace it, is the problem usually solved just by replacing the motor? Will I have to get a new regulator too?
Also, my window starts "sagging" over time, and goes back into the door, so there is a thin crack between the T-tops and window which lets water and snow get in. I do my best to pull the window up by hand so that it creates a better seal, but I don't know if this problem will persist when I replace the motor. Does the motor work to push the window up automatically when the door closes? Or is there something likely wrong with the regulator?
