TwinTurbo.NET: Nissan 300ZX forum - Difficult to drive without power steering on the Z. Also
Subject Difficult to drive without power steering on the Z. Also
Posted by doug8867 on January 27, 2014 at 6:43 AM
  This message has been viewed 250 times.
In Reply To can I just cut off power steering belt? posted by Mknightz32 on January 26, 2014 at 02:16 PM
Message our power steering takes ATF Dexron III fluid, not power steering fluid so if you discover you are low on fluid be sure to add the correct fluid to the reservoir, otherwise that can cause all kinds of problems and you would need to drain the system and refill with the proper fluid.
