TwinTurbo.NET: Nissan 300ZX forum - brake master cylinder, need confirmation please >>
Subject brake master cylinder, need confirmation please >>
Posted by stockplayerz(nyc) on January 23, 2014 at 2:37 PM
  This message has been viewed 314 times.
Message brake fluid slowly leaking from where brake master cylinder and booster meets. probably a seal going bad. my question is... if the fluid empties out, BUT i do NOT pump the brakes and just refill, there should be no air that should have entered into the lines correct? if i fill the reservoir at this point, should be normal pressure?
also, when i get a chance to replace the brake master cylinder, do i need to still go through the entire bleeding process (4 tires, abs unit), if i bench bleed the cylinder prior to installation? i heard its not necessary if you bench bleed it, just wanted confirmation.
