TwinTurbo.NET: Nissan 300ZX forum - It only takes ONE pinched o-ring to flood the engine
Subject It only takes ONE pinched o-ring to flood the engine
Posted by doug8867 on January 20, 2014 at 10:33 AM
  This message has been viewed 432 times.
In Reply To Re: You probably pinched the orings when you installed the posted by rico649 on January 20, 2014 at 06:01 AM
Message and prevent it from starting. Unfortunately, I've been there done that.
Given the symptoms you describe that would seem the most obvious culprit to your situation and would be worth rechecking. Good luck.
