TwinTurbo.NET: Nissan 300ZX forum - Re: Help mehhh 1990 n/a No Heat & Overheating
Subject Re: Help mehhh 1990 n/a No Heat & Overheating
Posted by wh0sjeff on January 19, 2014 at 2:51 AM
  This message has been viewed 215 times.
In Reply To Help mehhh 1990 n/a No Heat & Overheating posted by SugaDaddySpence on January 18, 2014 at 04:23 PM
Message usually those 2 together indicates a stuck open thermo providing your heater core isn't clogged. hot antifreeze traveling thru your heater core is what gives you heat, but if your thermo is stuck open the coolant isn't sitting in your engine long enough to get as hot as it needs to. or even more simple your coolant is rather low, but im sure you've already checked that, good luck
1
