TwinTurbo.NET: Nissan 300ZX forum - In my last reply I made a recommendation, not sure
Subject In my last reply I made a recommendation, not sure
Posted by SammybTT(TN) on January 18, 2014 at 10:55 AM
  This message has been viewed 321 times.
In Reply To make sure to watch it in 720p hd guys (n/m) posted by Tuner_Dev on January 17, 2014 at 07:14 PM
Message If you have read it yet however I would do a coolant system pressure check. Fill the radiator, use the tester and apply 14 psi of pressure and monitor the gauge to see if it holds the pressure or leaks down toward zero. Coolant loss could be a loose hose or possibly a pin hole in one of the hoses and hopefully not a head gasket. How much coolant are you losing? Quick check for a head gasket failure is to check the dip stick, oil fill cap, looking into the radiator, along with inspection of oil when doing an oil/filter change. Anything out of the norm is generally not good.
