TwinTurbo.NET: Nissan 300ZX forum - Re: If oil is on your plugs I would suspect either piston rings
Tuner_Dev
on January 16, 2014 at 2:28 AM
posted by SammybTT(TN)
on January 15, 2014 at 09:15 PM
Wouldn't bad rings cause bad compression numbers?
TT still smoking =( Appreciate any help.
Tuner_Dev
19:13:27 01/15/14
Can you at least pinpoint where it's coming from? (n/m)
YlwPrlZTT
20:08:09 01/15/14
Re: Can you at least pinpoint where it's coming from?
Tuner_Dev
02:29:45 01/16/14
Re: TT still smoking =( Appreciate any help.
BlackTwins
20:14:45 01/15/14
Re: Re: TT still smoking =( Appreciate any help.
Tuner_Dev
02:28:57 01/16/14
Re: Re: Re: TT still smoking =( Appreciate any help.
BlackTwins
17:25:29 01/20/14
SammybTT(TN)
21:15:51 01/15/14
Re: If oil is on your plugs I would suspect either piston rings -
Tuner_Dev
02:28:23 01/16/14
If I recall correctly the rings sets have different purposes
SammybTT(TN)
22:02:58 01/17/14
Here's a vid of the smoke. Thanks for any help guys.
Tuner_Dev
19:08:20 01/17/14
make sure to watch it in 720p hd guys (n/m)
Tuner_Dev
19:14:10 01/17/14
are you sure it's the pass side dp? It looks like drivers
YlwPrlZTT
20:36:01 01/17/14
Re: are you sure it's the pass side dp? It looks like drivers
Tuner_Dev
01:17:08 01/18/14
In my last reply I made a recommendation, not sure
SammybTT(TN)
10:55:56 01/18/14
Re: Here's a vid of the smoke. Thanks for any help guys.
BlackTwins
17:28:22 01/20/14
I don't know, that smoke looks kinda white, plus you're
YlwPrlZTT
20:42:11 01/17/14
Re: I don't know, that smoke looks kinda white, plus you're
Tuner_Dev
01:19:29 01/18/14
Sorry my reply got posted above and I am to lazy to copy and
SammybTT(TN)
10:57:40 01/18/14
Does the smoke smell like burning oil or unburnt gas? also
scottmt21
13:46:38 01/18/14
Re: Does the smoke smell like burning oil or unburnt gas? also
Tuner_Dev
15:05:34 01/19/14
Tuner_Dev
19:07:35 01/19/14
Like SammybTT said do a coolant pressure test. That should
YlwPrlZTT
19:37:52 01/20/14
Here is the info from the service manual.
YlwPrlZTT
19:40:49 01/20/14
Re: Here is the info from the service manual.
Tuner_Dev
10:30:29 01/22/14
