TwinTurbo.NET: Nissan 300ZX forum - TT still smoking =( Appreciate any help.
Subject TT still smoking =( Appreciate any help.
Posted by Tuner_Dev on January 15, 2014 at 7:13 PM
  This message has been viewed 337 times.
Message Car still smokes. It doesn't smoke on cold start up. It takes about a minute to see the smoke come out slowly and it will gradually get worst turning into a car covered in clouds of smoke. Checked plugs and look blackish fouled with some wetness on the thread and tip. Some more noticeable than others. Its not dripping soak but some wetness. I did compression test and all cyl were around 155-160 with a weak battery towards the last cylinder tested. Oil and coolant levels do drop from last time i topped off the car. Both fluids look clean. No signs of mixing. Put new plugs on and put the car back together. Tried to start her up but battery is dead. Will have to try again tomorrow. Right now I'm all out of ideas on what it can be. Turbos, Valve seals, Head gasket, or all lol. . Any ideas? thanks guys
